  1. I HAVE DOWNLOADED SOME MPEGS FROM THE NET THAT I USUALLY BURN TO CD. HOWEVER IT SEEMS THAT APOX 1 IN 3 DONT WORK.
    THEY PLAY FINE WHILST ON MY COMPUTER HARD DRIVE BUT WHEN I BURN THEM THEY WILL NOT PLAY ON EITHER MY COMPUTER OR DVD/VCD PLAYER. THEY BLACK SCREEN. REMEMBER THIS ONLY HAPPENS TO 1 IN APOX 3, THE OTHERS ARE FINE. I HAVE TRIED TO USE MPEG-CORRECTOR BUT THIS DID NOT WORK. ANY SUGGESTIONS ????
  2. Is this with alot of different downloads or just one that you received recently...if it is just the one then try re-encoding to mpg again and burning a small portion of the video to disk then test. This is the only thing i can think of and i hope it helps.
