Can someone tell why the movie Wintalkers (2 hr. 15 min.) will not fit on 2 cd's. I used clad dvd xp to rip movie Tmpge to encode to xvcd 2 cd's then tried to burn with nero to 2 700mb /80 min.cd's and nero says cd1 and cd2 are to big for cd. I thought 1 hr. 8 min. would fit on one cd so any help would be appreciated.
what bitrate did you use? should be 1300 for video and 128 for audio. what frame rate did you use should be 29.97 whats the size 352*240 ok and the last part thats very important in TMPEG you close the wizard and you put the settings manuallyOriginally Posted by rockettm
on the System tab you put Mpeg 1 Video CD Non Standard. and on audio put for bitrate 128. any questions write back.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
what size is the first part and the second part in mb cause in 1 cd you can put 800 mbs. ok and if your using nero burning rom do this put VCD and then it says creat standard and uncheck it.
what the heck you talkin bout cecilo...
if anything like this goes wrong you should doublecheck with a highspeed encode at bogstandard VCD... 1150 vid and 224 audio, mpg-1 VCD standard stream encoding.
For 68 minutes per disc you should be able to set the rate a fair bit higher than 1300+128.. 1440 and 160 / 1400 + 192 are within easy reach for a snug fit on non-overburnt 80 minutes disc.
Tho of course VBR is a better bet
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?
By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 16:12 -
Blu-ray or rip movies don't play in 5.1 surround sound. Help?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 15th Feb 2009, 17:07 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 01:43
