I was wondering if anyone could help me: I have downloaded part of an AVI video clip and I used the DivFix program so I could watch what I have downloaded. That all went fine but the file needs a certain codec to make the sound play. I have tried the Kristal codecs and that worked temporarily but then it went all strange and I had to delete it. I have tried version 4 of the Divx codec and also an Angel Potion codec but none have worked. Has this got anything to do with the file being incomplete (even though I used the DivFix program)? Or does anyone know an alternate to the Kristal codec thingy? Thanks![]()
Try uninstalling all your codecs, then install just the krystal codecs and see if that helps. Not all the codecs are work together on the same system.
Vejita-sama,
How do you uninstall all or one codec... I mean where do you go to uninstall them?
Right, sorry.
1) Open control panels
2) Double click on 'sound and multimedia'
3) Choose the devices tab
4) Look under audio codecs
Just click on each one, choose properties, and then remove. M$ doesn't make it that easy
And of course reboot, before trying to install the new codec/s. Luck
AVI files with Divx codecs - will they play?
By pooksahib in forum Video ConversionReplies: 7Last Post: 29th Jan 2011, 15:59 -
pls. help: converting .rmvb files using ffmpegX
By Dolly in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2009, 14:32 -
pls or m3u to avi
By py52126 in forum Video ConversionReplies: 1Last Post: 20th Jan 2009, 14:35 -
Anyone know how play IVM video files pls?
By amdk62 in forum Newbie / General discussionsReplies: 15Last Post: 27th Sep 2008, 08:52 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 04:17
