I have several NTSC svcd files i want to put to dvd. I have movie factory2 which seems as though it will do it ok but.....................
It looks like it will take forever and i am worrying about the possibility of an asteroid impact b4 it finishes! Is there a quicker method? Tried TMPGEnc but says file is unsupported.
Thx
Lash
have a little mess on with dvd2avi & strip them to there component parts d2v & wav then use tmpeg to re-encode as a dvdmpeg thats how I put most of my svcd's onto dvdr... also there is a small prog knocking around called svcdtodvdmpg it may be on this site or dooms site but if not do a search for it as my m8 says it works nicely.
PAL DVDS to NTSC?
By KaiserD2 in forum Video ConversionReplies: 11Last Post: 13th Apr 2011, 12:42 -
Wedding DVDs conversion from PAL to NTSC help
By jag3er in forum MacReplies: 6Last Post: 14th Nov 2010, 18:23 -
Converting PAL DVDs to NTSC For HDTV
By Startropic1 in forum DVD RippingReplies: 8Last Post: 9th Jun 2010, 09:34 -
Help convert PAL to NTSC DVDs
By Jedi5 in forum Newbie / General discussionsReplies: 15Last Post: 30th Apr 2008, 07:24 -
Need major help with DVDs Pal/NTSC
By dartingaround in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2007, 19:04
