i have just installed an advc-50 and hooked it up to my old dvraptor firewire card , it captures dv from my dv-camcorder no problems but i can't get it to recognise a video recorder what software works wih this setup
thanks in advance
Video recorder?
The only thing that should be recognized by your computer is the advc unit.
I have one myself.
I use DVIO and Pinnacle studio 8.
I think you can capture with alot of programs with this baby.
I dont understand what u mean with recognizig..
All data that comes into the advc digital / analog comes out DIGITAL!
Good luck! -
well i connect the video recorder up to the advc-50 start the video and try to capture but nothing seems to be captured , i think i am missing something , although i have no problems with dv just analogue
What capture program are you using. If you happen to be using Windows Movie Maker capture, I had terrible trouble using this program with my ADVC-50 with a VCR attached. I now use Edit Studio 2's Capture program and have not had any trouble for ages.
Cole
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
Canopus ADVC 110 or Canon HV40 for Best Capture
By jaydub in forum Capturing and VCRReplies: 4Last Post: 21st Sep 2010, 15:55 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Capture Software Needed with the Canopus ADVC-110 ??
By christopheramos in forum Capturing and VCRReplies: 15Last Post: 23rd Feb 2009, 16:42 -
Capture problem with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 26th Dec 2007, 21:20
