I am having problems with a film i have when i try to join it. Originally it is in 4 parts and i want it in 2 so i can copy it to 2 dvd's. Parts 3 and 4 have joined fine. When i try to join parts 1 and 2 i lose the last 25 minutes of the second part. All parts played fine individually and the joined part 3 and 4 are excellent. Part 2 plays a full 45 mins but only the first 20 minutes joins to part 1. I am using TPPGEnc. What could it be?
Lash
There is absolutely no need to join them. You gain nothing by joining.
Splitting is necessary because sometimes you have to split a file to fit it into CD. Joining can only screw things up. -
If i do not join them then I would have to run the dvd on one scene for 45 mins then when it stops and then switch to the next scene whereas if i join them i get a 1 full film on eack dvd . Won't I???????
Lash -
No really. Your authoring program will control how you want them to be played. There are so many vob files on DVD, but they don't play one vob and stop, do they? Authoring decides navigation. That's why joining is never necessary.
Joining two MKV files, problems with track IDs
By nry in forum Video ConversionReplies: 3Last Post: 21st Jan 2018, 00:47 -
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 10:47 -
Sanyo HD1000 MP4 File joining - codec problems
By 737 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Apr 2008, 14:26 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 04:48 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 21:18
