i have alaptop and desktop, but what i wanna do is weird, but i wanna try it...i wanna hook my lcd screen up to my laptop...there is a serial connector in the back to handle this...but whne i do it nothing happens...holla back.....
Results 1 to 15 of 15
Check your laptop manual, ther is usually a function key sequence that will switch between internal(laptop screen), external(VGA connector on back of laptop), or both internal and external. It's normally labeled LCD/CRT on the keyboard.
plug in and reboot..
To my knowledge, VGA isnt hot, its cold so u need to reboot for it to work. -
Also beware if you are trying to play Mpeg2 you need an mpeg 2 card.
You can also use the Dual Monitor option in Windows when you hook up an external Monitor to a Laptop. I have mine set up at home like that and its great. I will never go back to just one Monitor.
"Sleep-
Those little slices of Death;
How I loath them." -
"Also beware if you are trying to play Mpeg2 you need an mpeg 2 card." Huh??? Maybe I'm missing something with laptops, but with desktops all you need to do is install an MPEG-2 codec (software) to be able to play MPEG-2 files.
Hurts my eyes sometimes...
I cant fit it on my desk, for odvious reasons. So i fit it where my T.V was.
I use my ATI to watch T.V and the screen has a DVD player in the back but i never use it because quality is CRAP ! -
where the hell did you get it from and at what price...holla back
Got it from Japan, along with some other goodies...
Its in Japanese. Its basically a 32 Inch Flat Panel with a VGA cord, progressive. -
is there a web site i can get on at, how much did u pay for it..holla
No i physically went to Japan. Hard as hell to get a hotel or apartment overthere. I spent 7000$
need help, i want to hook my laptop to the tv
By sonicslayer in forum Newbie / General discussionsReplies: 15Last Post: 10th Jul 2011, 15:23 -
Laptop LCD screen to TV
By cynikalhedonist in forum DVB / IPTVReplies: 4Last Post: 28th Apr 2011, 08:07 -
Im looking to hook my laptop to my tv can I use vga to componet for this
By marionr26 in forum DVB / IPTVReplies: 35Last Post: 5th Feb 2010, 22:46 -
Looking to hook my laptop up to my 42 plasma
By marionr26 in forum Software PlayingReplies: 12Last Post: 26th Nov 2009, 16:35 -
Laptop to LCD HDTV--Screen Size issues on TV
By blackdog69 in forum DVB / IPTVReplies: 7Last Post: 13th Oct 2008, 17:35
