I used smartripper to rip The Last Boyscout and it worked very fast and good quality. But since it is in vob file I have to convert it to vcd (preferably svcd) which I tried with TMPGEnc. It says it cannot read the vob file or it is unsupported. Then I try going to merge and cut, load movie and everything and it works fine, but when it is making the svcd it doesn't make any audio. Is there anyway I can make it work a similair way, or a different way, but I would like to use smartripper. Thankyou.
Take a look a the at the links to the left, esp the 'DVD Rip' one
Basically you can't just load the VOBs in TMPGenc, you need to generate seperate video and wav files (normally w/ DVD2AVI).
If you're a complete newbie you might want to look at DVD2SVCD. You can d/load the newest software bundle at http://dvd2svcd.doom9.net however the guide for it is at http://www.doom9.org (look under 'the guides') you'll also find a link there to d/load CCE 2.5sp demo. The demo will place a watermark/logo in the bottom right of your encoded MPEG; however, I've heard that there's a crack to remove this
Anyway, read the guide to the left or the one at: http://www.flexion.org/video/DVDConv/DVD2AVI/
How close is too close
By SpectateSwamp in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2011, 22:25 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
Close GOPs
By Ar'ina in forum Authoring (DVD)Replies: 5Last Post: 23rd Dec 2007, 03:22 -
CompUSA to Close All Stores
By MJA in forum Off topicReplies: 13Last Post: 10th Dec 2007, 06:58
