  1. I have tried with a number of different files, basically after creating a valid mpg for burning if I use TMPGEnc and split the file in two the resulting mpg files return an error when you try to create the vcd with them,if I then accept and request to burn anyway, the size is misreported and the burner will not accept saying not enough space on CD
  2. Whoops, looked like I solved my own problem, the correct button would be worth looking at wouldn't it.
  3. what did you do to fix it?
    when I spilt the mpg files and try to burn them with nero it says that it is in an improper format and do I want to continue? choose yes and it will burn but when trying to veiw the dat file w/media player or a dvd player the file will not load. what am I doing wrong
  4. Make sure you choose the correct option in the drop down menu when cutting. The default will give you errors.
  5. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    thanks that did the trick, thanks for the help
