  1. I'm trying to convert my TV Rips in VCD format to DVD so I can free up some space... only problem is that I don't know how to do it. I only need to convert the audio to 48k, no video (re)encoding.
    I used FFMPEG on the mpg file to make the 48k mp2 but it just says "starting" but doesn't actually encode it.
    Any other programs I can use to take my MPG file and just encode the audio... or use the demuxed file (m1a) and just reencode that.
    thx.
    [*]_BonKer$_[*]
  2. Try MoreMissingTools homepage.mac.com/rnc
    mp2 -> wav 48k
    wav -> mp2
  3. Originally Posted by [*
    _BonKerS_[*]]I used FFMPEG on the mpg file to make the 48k mp2 but it just says "starting" but doesn't actually encode it.
    Are you using the .mp2 preset? (version 0.0.6j). Or use Ross' tools.
