i used the doom9's guide (http://www.doom9.org/mpg/dvdmotion_pro_guide.htm) everything went good except when i tried to make a chapter list. i make a .chp file using this syntax :
but when i import it in dvdmaestro, i get a popup telling me that 0 chapters were imported !! does somebody already had this problem ?Code:$Spruce_IFrame_List 00:00:00:00 00:03:42:50 00:04:32:23 00:05:54:11 ...
Thats easy, and I'm sure a lot of us have been there...
You'll find you video does not start at 00:00:00:00, it proabaly will start at 01:00:00:00 if you encoded in CCE and didn't alter the default start timecode, or if you demuxed a DVD it could well start just before 01:00:00:00.
Anyway as you video is prepared now, just check in DVDMaestro the start timecode of the video, then add this onto the chapter times, if it's 01:00:00:00 it's easy to add 1 onto the hour column.
In future set the timecode to 00:00:00:00 in CCE or use DVDDecryter 3.1.5.0 for ripping DVDs and tell it to patch the M2V timecode to 00:00:00:00.
Starting video after zero is left over from when tape master was used, it allowed for spin up of the tape player.
Neil
Importing Chapters into TMPGEnc from XML files
By TheLaserdisc in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2012, 16:05 -
Problem with Sony Vegas importing DVDs
By aporreca in forum EditingReplies: 2Last Post: 31st May 2010, 09:28 -
Smoothness problem while importing avchd files
By effegieffe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 3rd Mar 2010, 21:55 -
problem importing wav into EditStudio
By ecc in forum EditingReplies: 4Last Post: 20th May 2008, 14:41 -
Problem importing video into VirtualEdit
By acid_burn in forum EditingReplies: 3Last Post: 23rd May 2007, 10:07
