Hi,
How can I determine what CODECs I already have in my PC? Is there a programme that can let me determine this?
Thank you for your helpful suggestions!
Mertsi
I am not sure if it is the same on all pc's but in my control panel I have an icon labelled system information and codecs is a pull down tab within that.
yeah, you'll be able to find that either in the control panel as he says or on the Windows Start Menu. Look under Accessories - System Tools, and click on system information. Then expand (hit the plus sign) the components menu, then the multimedia menu, here is where you will find what audio and video codecs are installed.
(these instructions apply to XP and 2000)
Prospero -
gspot (located in the Tools section)...
Download it, execute it and click on
View -> Installed Codec
you have a video or audio choice
goodluck! -
Thank you all for your suggestions. Now I know how to detect the codecs I have installed.
Once again thank you!
Good luck
Mertsi
looking to find out the standard in video codecs that are used by default
By rickywh in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2011, 10:58 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Window Media Encoder Can't find codecs
By Ensign in forum Video ConversionReplies: 2Last Post: 18th Jul 2008, 11:33 -
CODECS-Too Many? Find and Clean-A/V sync Errors
By mrlewp in forum Software PlayingReplies: 9Last Post: 17th Apr 2008, 05:33 -
trying to find proper codecs
By onlyoneman in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2007, 19:43
