    Apr 2003
    phoenix, AZ
    I am trying to make a VCD of concert mpegs for the first time. I downloaded the Nero demo to burn them to disk. I understand everything fine, but everytime I attempt the burn it gets to 99-100% done and then the burn fails. Around 96% the used read buffer begins to drop until it eventually hits 0%. Then I get an error message that states "logical unit not ready, operation in progess", then right after that I get a message that says "burn process failed". I have attempted the burn at every speed and it always fails. I am a computer idiot, so am I doing something wrong? Is it the files (other people have had no problems burning them)? Any idea what those error messages mean? Or is there another program I should use? Any help would be greatly appreciated. Thanks!
  2. I personally would never use a demo
    There are also other burning software out there.
    I use NTI cdMaker deluxe verry good.
    Good luck!
  3. I have never heard of that error before. I agree with mj try using the full version of nero or another burning program. Do the files operate correctly on your pc ?.
  4. Banned
    Nov 2002
    Pgh Area
    MJ2505,
    A better question is, do the CDs work? I have gotten the burn failed message a few times, done it a second time, got a bad burn, said the hell with it, let me try it, and the disk worked, VCD, SVCD, music, data. Sometimes the program doesn't know what it's talking about.
    Apr 2003
    phoenix, AZ
    Thanks for the help. The mpeg files work great on the computer. gmatov, I took your advice and tried the vcd's that failed on my dvd player. They didn't work. I then tried them on the computer by playing them in PowerDVD and they worked, they just didn't have any color. So I thought maybe my dvd player didn't support VCD. I have a Toshiba sd200-8u. I checked the compatability list on this site, my DVD player isn't listed, but it looks like all Toshibas listed support VCD. So, now I don't know what the problem is. I should probably just try it with a new program. If anyone knows if the sd200-8u supports VCD or not, that information would be greatly appreciated. Thanks for the help.
  6. Banned
    Nov 2002
    Pgh Area
    mj2505,
    I think your player is listed as a 2008. 4 reports say that it won't play anything, except 1 said he got it to play CD-RW.
    Are you using a VCD/SVCD program to convert the mpegs to VCD/SVCD format?
    I don't know if you can just burn what you have. Hell, I don't even know what you have.
