i dont know where to find out about this so im asking you guys.
one of the features i like most about dvds are the extra scenes and all the other extras dvds offere -- question is do vcd copies of dvd retain this extra stuff or is it just a copy of the movie
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Movie only. Most of the features are also video files on the disk you could rip too if you took the time to figure out which VOB has which videos, maybe. -
When smart ripper does the scan to rip the vob's for the movie, it chooses the largest sized vob's. Just go into the smaller sized ones, and you will either get alternate frames, or some special features.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>i dont know where to find out about this so im asking you guys.
one of the features i like most about dvds are the extra scenes and all the other extras dvds offere -- question is do vcd copies </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It depends on how much effort you want to put into it.
VCDs won't support seamless branching or multi-angles, but in terms of menus, trailers, delected scenes, biography, etc., these can all be put onto a S/VCD.
SVCDs further support multiple languages (2) and removable subtitles (4, but no well supported in hardware).
Regards.
Michael Tam
w: Morsels of Evidence
Adding stripped extras to a DVD
By zdzdz in forum Authoring (DVD)Replies: 6Last Post: 20th Sep 2008, 04:38 -
How do you burn a playable DVD with an Extras Folder?
By something random in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2008, 10:24 -
Stripping DVD extras, while retaining menu
By Hurre in forum DVD RippingReplies: 3Last Post: 19th Feb 2008, 10:14 -
DVD Extras Not Playing Back in Standalone
By SamNZDat in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 03:29 -
DVD edit w/ subtitles and extras
By joelson in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 14:23
