Hi there,
If the DVD is a dual layer one (DVD-9), there is a layer break, and whenever there is a layer break, the subtitle's Vob ID is changed from 1 to 2 (be sure not to mix up with Vob Cell). When I authored my final output, IFO Edit did not recognize when it reached the subtitle's layer break (i.e. where subtitle's Vob ID changing from 1 to 2), therefore, the 2nd half of the movie had NO subtitle at all. How can I change the subtitle's Vob ID (use "1" for the whole set of subtitle) so that IFO Edit will recognize it? By the way, I used VOB Edit to rip my subtitle stream. Thanks in advance!
I used subresync.exe (a file inside VobSub.zip) to check, it showed subtitle's Vob ID.
Results 1 to 1 of 1
how to separate subtitle from vob or mkv in srt file
By ashe09 in forum SubtitleReplies: 5Last Post: 10th Oct 2011, 03:38 -
Want to edit some words in a subtitle of a Vob file
By prithvi in forum SubtitleReplies: 8Last Post: 16th Feb 2011, 15:00 -
extract vob with subtitle fixed!
By c0ntr0lz in forum SubtitleReplies: 1Last Post: 6th Jun 2010, 01:40 -
How to convert MKV to VOB but without subtitle loss?
By c1steady in forum Authoring (DVD)Replies: 13Last Post: 14th Sep 2009, 08:31 -
How convert MKV to VOB but without subtitle loss?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 04:55
