Is there any reason why it takes 4 hours to encode 30 seconds of video? I have a pentium III and 192MB RAM. This is a 3 minute ASF file I am trying to encode to MPG for VCD burning. It says it will 18 hours to encode each file, is this normal?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I Have a Duron800 and 256MB RAM and a full length movie takes about 3hours to complete. A thirty second clip would take about one minute and thirty seconds for VCD use. My source file was from a DVD rip though, so was VOB files compiled with DVDAVI. Don't think ASF files would take any longer though, I have encoded AVI files from video captures with the same times. -
asf is heavley encoded.
tmpg has to decode it, then encode it.
i've noticed avi's made in ati vcr 2 take longer to encode than uncompressed rgb. -
Hello!
Plz help. I got Thunderbird 750, 384mb RAM, and my comp encode a 2 hour movie @ 20 hour. Whats the problem? Is this normal? I rip the DVD, and make a project file (DVD2AVI).
I use TmpgEnc. Why is so slow for me??
Sorry for my bad english.
XTC_HUN -
THE PROBLEM IS TMPEG ITS A GOOD PROG
BUT IF YOU HAVE NOT GOT A REALLY FAST PC IT S SHIT
BEST USE FLASK WITH THE LSX PLUG IN OR SOMETHING
OR EVEN TRY DVDX AND RIP STRAIGHT FROM DVD
Time needed to render is relative to many factors:
1. your CPU speed
2. avaliable system resources
3. how many, what kind of filters, etc.
4. if or not you hard drive is fragemented
5. which application you use
Just for some very rough ballpark idea I get a factor of between 6 to 1 and 9 to 1 meaning a one minute source AVI file with typical filtering options rendered to SVC at typical bitrates takes on average between 3 to 9 minutes for every minute of video to be processed on my rather typical AMD 1200Mhz. Times are less if you just encode from AVI to MPEG-1 as-is meaning no advanced filtering options. I've gotten away with less than 2 to 1 if I'm happy with the source file and not fussing with filters trying to "improve" things.
My advice is if you know your system is stable, don't overheat or lock-up simply start to render longer videos just before going to bed and in the morning you'll have your file. Yes, it does take that long assuming we're talking about 40 minute or longer projects and you do try to apply filters. -
I can send you a better encoder, e-mail me at Damoviemastarz@yahoo.com or AIM me at Woodya2004
later
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
