I've been doing video capture for about three months now and I use the MJPEG codec at 18 quality capturing at 640 x 480. I have gotten some optimal results, but I was tweaking the card to try to improve quality and I found out I could not capture higher than the height of 480. I tried capturing at 720x480, that worked. Then I moved it to 720x576 and the picture has some wierd green lines on the bottom. Can somebody help? I am running windows xp sp1 with direct x 9. I tried uninstalling direct x 9, no luck, still the same problem. I am running MMC 7.7
Results 1 to 1 of 1
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
Video height of 480 doesn't fill screen
By Grunberg in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 20:15 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24
