Normally IC7 does not do .ISO but on one occasion I got it do .ISO (over 4.00 gb) no .pdi. It is true and no joke. However I could not get it to do it again. I know I click other files when I had save to screen. I was able to load the .ISO image into Daemontools.
Does anybody knows how to get IC7 to do image file for sure?
Not sure what you're asking?
1) To use a ripped ISO image as the source for IC just mount the ISO file in DAEMON tools.
2) IC doesn't output to ISO, but there's a program/tool "PDI2ISO" which will convert the IC output to ISO so you can work with/burn that. -
I am saying that IC7 outputted to .ISO from VIDEO_TS directory which I loaded using Daemon tools. I used no other tools, I am aware of other tools.
Hmm, if what you say is true, I guess you could do it by chosing "other files" at the save screen, and save it as .iso.
However I would not do this anyway... PDI2ISO seems to do the conversion without any problems, and I do not wish to have a corrput file after the IC progress. I accept the .pdi output!I wanna be bigger, stronger, drive a faster car... -
Thing is that I did not type as .ISO extension. It did it automatically.
PDI2ISO has failed 95% of the time comes with an error at the end same thing with PDI to ISO Convertor. Does anybody has solutions for these? Is annoying.
Thanks. -
yep, I tried that way ages ago and it don't work
it still splits the ISO into separate VOB's and anything contained after the end of the 1st ISO file will not work during playback without problems
all it is doing is missing the .PDI of the end
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
ISO help
By Jacks_Daddy07 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2009, 15:19 -
ISO
By shapper in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2008, 09:31 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
ISO
By bogb in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 11:08
