  1. I recently purchased DVDxCopy v1.5 and was wondering if there is a way to get rid of the Backup Warning screen put on at the beginning of the copy besides using IFOedit. I heard there is a way to do it, any and all info would be greatly appreciated. Thanks
  2. Delete the file.
    Create net .IFO and TS files using DVDToolbox. Or just rip the movie only usind DVDToolbox.
  3. From the Guide/How-To section of this site:
    DVDXCOPY improvements - or how to remove .VOB ID's
    Are you using DVDXCopy and want to remove the 321 disclaimer then read this guide.
  4. Whoops... disregard my post above. I just realized the guide uses IFOEdit.
    Jan 2002
    NEW ORLEANS
    please read my post in dvd to dvdr in titled DVD SHRINK WINS HANDS DOWN then go sell your copy of dvd x copy on ebay, or just deleted like i did..........thanks
    ONLY THE DEAD HAVE SEEN THE END OF WAR.
    some where in the midwest
    in this link you said "run in 256" that is in the power dvd correct?
    also i am very new
    newbie 101
    thanks
    those you live in glass houses should not throw stones.
  7. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    No he means vobrator, its very unstable, but if you make it run in only 256 colors it a little better behaved. Actually quite a bit better, but not perfect.
