I have made a MPEG file using DVDx. I have VCDEasy (Version 1.1.5) When I try to burn my MPEG onto a CDR I cannot. The box that says Burn is Greyed out and when I pass the cursor over the box I get the message the Burn is not available when the output is XML only. How do I resolve this problem.
Any help would be appreciated. You can post it here or E-Mail your response to me. My E-Mail is Penguin@mail.gemsi.com.
Thank you in advance for your assistance.
This could be as simple as unchecking the "Generate the XML file only" box which is to the left and 2 lines below where the "Burn" box is.
DougPenguin1962:
It looks like RowMan has the answer to your problem. My copy of VCDEasy normally burns to CD fine, but if I check "Generate the XML file only" it does not work. So, uncheck "Generate the XML file only" and it should work fine. -
if you are still stuck just produce the Bin/Cue files and burn with NERO or the like.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
canot remove viruses
By romanstopme in forum ComputerReplies: 3Last Post: 22nd Dec 2008, 11:17 -
canot connect to modem
By romanstopme in forum ComputerReplies: 5Last Post: 17th Dec 2008, 13:39 -
canot render or export
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2008, 16:07 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00
