can you compress an MPEG ?? I want to make my Mpeg smaller so i could make a Video CD, is it possible..??
You realize that MPEG IS compression. It is compression for an uncompressed source such as an .avi or .wav
To make an mpeg smaller you must reduce the bitrate. -
if its a compliant mpg in vcd format it should burn to vcd no prob if its not just run it through tempge with a vcd template then burn it. you need a burning program that supports vcd like nero,ez cd creator,sonycd extreme etc
compress ?
you can encode it to MPEG4 as ASF or DIVX
wish to know how ???
go to http://www.geocities.com/mpgtoasf
How to compress videofiles?
By BigDrago in forum Video ConversionReplies: 11Last Post: 9th Aug 2011, 12:00 -
How to compress this "mpeg nightmare scene" ?
By cd090580 in forum Video ConversionReplies: 35Last Post: 17th Apr 2009, 11:52 -
compress mpeg file
By bountylord in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2008, 10:33 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 12:03 -
How Do I Compress a File?
By The Monkees in forum Video ConversionReplies: 3Last Post: 11th May 2007, 17:38
