i converted a dvd to non-standard vcd. i used a higher resolution and a higher bitrate and i used variable bitrate. when i play it, there is a time stamp error. the first half is about 50 minutes but it tells me it is only 10 minutes. i wanted to clip the file because it is over 800 megs but the time stamp issue caused problems. i tried multiplexing and i also tried correcting the header, but it still wont work. i dont want to encode it again because i encode using the highest quality method on tmpgenc which means about an 8 hour encode for an hour and a half movie. any suggestions?
