My brother has ordered AOL DSL and what I have observed is he has to connect using his AOL account before you can search the net. If I hit IE prior to his logging into AOL, I cannot reached the site.
If that is the case, how can I share that connection using a router? In the router, there is login and password so that is where we put in his AOL login parameters?
Are you confined to AOL's browser or not?
Thank you for any help
Set the router to Standard pppoe settings and fill in the user name as"user@aol.com and your pass word and you are set to go.
Aol has been cracked so you are not confined to the bloatware .
For more info go to DSLReports.com
Sharing internet connection via bluetooth
By alegator in forum ComputerReplies: 5Last Post: 15th Sep 2010, 01:18 -
DSL connection problem - tweak
By Jeremiah58 in forum ComputerReplies: 8Last Post: 14th Feb 2010, 18:16 -
aol number
By Mr anderson in forum ComputerReplies: 5Last Post: 10th Oct 2008, 06:39 -
Easy way to know if someone else is sharing wireless connection?
By edong in forum ComputerReplies: 5Last Post: 18th Feb 2008, 19:37 -
Help with Wireless connection and file sharing in Windows Vista
By Ollie6431 in forum ComputerReplies: 16Last Post: 10th Feb 2008, 21:52
