hi i am new to this dvd burning and i dont want to waste a million dvds. and have them not work at all. ok i started out by decrypting a dvd onto my harddrive. then from there, because it was a 2-layer dvd, i used dvdtoolbox. did what i had to do there and then burned a data dvd i believe and now when i pop it in my smasun dvd player, my xbox dvd player, and my sony 5disc dvd player they all dont read the rom. can someone help me out here. i am using the memorez drd +r and +rw that came with the burner. but i also have 50 fuji film dvd +r. anyones help would be greatly appreciated. thanks
Closed Thread
What burning program are you using? When burning a dvdr it must be dvd-video compliant in order for your dvd player to read it. You must create a VIDEO_TS and an AUDIO_TS folder on the disks. Put all the information that dvdtoolbox created in the VIDEO_TS folder and leave the AUDIO_TS folder blank. When burning make sure the file format is compatable with your dvd player. I use UDF 1.02 file format.
@sheydel
Yeah you can get a serial number from www.dvdxcopy.com when you send them 100 dollars... But I think they have a special for less... GO FOR IT!!!
dhluke
P.S.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVDR's with hdd question
By tannenba in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2011, 13:43 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 11:29 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 16:06 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 21:29
