IF your writer stay in PIO mode even if you have selected use DMA and it supports DMA try this to fix it. It worked for my PIONEER A05!!!
If XP detects enough DMA errors on a drive it switches to PIO and won't let you change it.
The fix is to remove MasterIdDataCheckSum or SlaveIdDataCheckSum depending on the drive at this registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}
Choose 001 if the drive is on your primary IDE channel, 002 if on your secondary.
Another option is to remove your primary/secondary IDE channel and let XP rebuild them, but that's a little more hazardous.
Thanks to jhughe90 at the DVDxCOPY forum for the tip!
I think an easy way to fix dots flickering (sample included)
By jairovital in forum RestorationReplies: 28Last Post: 11th Jan 2012, 16:39 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 16:26 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 23:35 -
VLC playing problem - probably easy fix.. but I suck.
By SteveMKIIDub in forum Software PlayingReplies: 6Last Post: 22nd May 2007, 14:59
