Ok, i've used DVDlab to put 6 SVCD's (3 movies) on 1 dvd. Well it was too big so i cutted of the credits at the end. Only now it's still 30mb too big!!Is there any way i can reduce the size of one of the movies without cutting in the movie?
You can try running it through DVDshrink. I believe you can select .IFO files and then proceed to compress it a bit.
Dunno if this will work for you, as I have tried DVDshrink-ing a DVD created by DVDlab, and I get 'vob mapping' errors =(Cheers~
JCPicache -
DvdShrink works fine, it all fits on a dvd now. I tried burning a dvd+rw and it worked, only i can't select one button on the main menu by pressing up and down on my remote
Overburn it or drop your audio down to a lower bitrate in 1 movie.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You can't overburn a DVD+RW, at least i can't with nero. But i'll try to downsample my audio from 196 kbit to a lower bitrate. Is there a program you can do that with?
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
21.7GB on a DVD?
By sebrame in forum Authoring (DVD)Replies: 8Last Post: 1st Feb 2010, 16:56 -
can you help me how to burn a 8 episode anime video to a 4.7gb size DVD?
By komiya in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2008, 04:15 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 22:14 -
question about total file size of DVD main movie and how to back up
By jimdagys in forum DVD RippingReplies: 6Last Post: 28th Oct 2007, 20:34
