Can anyone clarify the difference between 90 and 99 minute CD-Rs?
I see some disks advertised as 90 minute 'plus'
Others as '90 minute', and more at 'up to 99 minute'.
I have successfully used my CD drive to write 99 minutes, so I am confident that the drive will accept the media, but which to buy? Are all the disks the same but differ in the QA test?
Curiously, of those that choose to identify the capacity, all seem to suggest a capacity of 870 Mb, so as a postscript to this question, perhaps someone can tell me what file size settings I should use in TMPGenc.
Thanks to all in advance
DONT KNOW ABOUT 90MIN PLUS BUT ACCORDING TO THE 99 MIN INFINITI DISCS I HAVE THEY ARE 900 MG. i THINK IT ALSO DEPENDS ON THE TYPE OF WRITER YOU HAVE FOR THE MAX SIZE POSSIBLE YOU CAN WRITE.
Before I bought a DVD-r drive I made many XVCD. VCDEasy was the program that I could get the most on a disc with. 80 min cdr - approx 830 mb, 90 min cdr - 930 mb, 99 min cdr 1008 mb, all noncompliant vcd format. I threw many discs in the garbage because they would stop playing at about 88 and a half minutes in my 2 Pioneer players, 308 3 disc and 603 5 disc. I tried one in my daughters GE1101P and it played just fine right to 98 min so it was the player not the discs. Yes I did go buy a GE, maybe not Pioneer playback quality but way better than Apex and it plays everything. ................ harrymj3
90min data(mode 1)=800MB,90min audio/video(mode 2)=880MB
99min data(mode 1)=870MB,99min audio/video(mode 2)=950MB
I use Ritek 90/99min CD-R and they are rated at 24x but will burn at 48x with no errors. 8)
www.allmediaoutlet.com/9099minutes.html -
I had the same depressing scenario of harrymj3 - PC DVD-Rom recognised all 99 minutes of video/audio, but my Pioneer DVD Player would only play up close to 90 minutes. My el-cheapo car stereo, however, plays the full 99 minutes, so at least I can use them there.
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 10:26 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 19:47 -
Best way to concatenate nine 10-minute Flash videos?
By Verlager in forum LinuxReplies: 18Last Post: 27th Apr 2009, 02:28 -
Get snapshots from video files every XX minute
By roglopes in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2008, 22:07 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 18:50
