Can anyone please help?
I am new to copying dvd to dvd-r but i have done a few wich have all been sucsessful.I tried to greek wedding.I used dvd decrypter to rip to hd then i used dvd95 to convert the file i have used these two progs on all my copys and has always worked.I then put the film onto dvd-r using copytodvd.I followed the tutorials to the word from this site.The thing is is that when i try to play the film in my dvd player it says insert playable disc.It does this in both of my standalone players.I just get a slight clicking noise as if its searching for something.I then tried it in my pc with power dvd and it works.It also works in my sons playstation 2.What is wrong.I have tried different media with the same results and different players.
Please help.
Many thanks in advance,Ryan.
Check compatability with players (see left hand column) and what disks are you using, some do and some don't.
ru sure ur dvd player is compatible with dvdr check on the left side in the dvd players section or check if the disc is protected with microvision or some kinda copy protection.
not sure about this :-
rip the movie with smart ripper ( make sure the Demicrovision box is checked) and use some tool to burn it
iam sure its the protection or compatible problem -
Not really related to your problem but if you strip out either the widescreen or fullscreen version of this movie, then it will fit on a blank dvd-r.
Thanks for the replys guys.How do i check the disc for protection and will smartripper work in the same way as dvd decrypterI.E. rip the full film inc. menus and create an ifo for dvd95 to work?
Thanks,Ryan.
greek subtitles do not show at all!!
By eleeeni in forum ffmpegX general discussionReplies: 7Last Post: 14th Jan 2013, 10:11 -
the greek subtitles do not show at all
By eleeeni in forum Video ConversionReplies: 2Last Post: 26th Jun 2011, 14:52 -
Is anybody here Greek &/or an aficionado of Greek food & drink?
By Xylob the Destroyer in forum Off topicReplies: 20Last Post: 10th Jan 2011, 19:48 -
Problem with GREEK SUBTITLES
By neroman00 in forum Video ConversionReplies: 3Last Post: 29th Dec 2009, 09:48 -
GREEK sUBTITLES HELP.
By AndreasTorous in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 12:07
