I used (S)VCD2DVDMPG to convert the vcd to an audio and videostream. which works great btw. But the problem came when i tried to watch the dvd i burned with nero and authored with maestro. There is a lot of bluring and blocks at the bottom of the video which isn't there on the vcd.
Anyone else tried to burn of tv episodes and didn't have this problem?
Yf
I had other issues with TV eps (sync mainly). Mostly because the mpegs had been edited for adverts etc. However, I can't help unless I see the mpeg.
First use some splitting tool such as hjsplit to cut a small chunk for example 3-4 MB from the file, try it so see if it has the same problem then upload it somewhere for me to download. If you have no where then I'll PM you a email address.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
extracting vobs by episodes
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2010, 00:54 -
Multiple episodes in one vts
By c9806961 in forum DVD RippingReplies: 12Last Post: 15th Aug 2009, 02:35 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 20:47 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09
