I am using Pinnacle Studio 8 to output my video and wav file. I export using pcm 16 bit stereo 48 kHz. These settings can be used for DVD Architect. However after encoding my avi file to mpeg2 using tmpecnc the files have to be recompressed in DVD Architect. The end result is awful audio quality. When I look into Tmpegnc to check the settings I noticed a Bit rate setting for the audio. It’s set for 338; however the lowest is 64 which is too high for DVD Architect. Any suggestions on what I should do?
Results 1 to 1 of 1
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 00:19 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 14:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 03:00
