my mpg file which i ripped off from a vcd(with scratches) has those missing frames & getting stuck even when sound is playing ok .. problems ... this occurs at several places of the file so i cant isolate the particular time at which it occurs .. when i tried to re-encode it tmpgenc also gets stuck .. what shud i do to fix this problem without anything happening to the video\audio sync of the file.
Have you tried saving the audio in virtualdub first (to WAV) then feeding the video only into tempgenc after de-multiplexing it?
you can change the audio later using toolame & toolame GUI.
You can multiplex both later.
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 22:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
