Anything good for playing VCDs on I have a the Sony NS300 and I don't really like it (bought it from a pawn shop) I like the Apex much better but it was messing up on me. Anything out there of a decent price that will play vcds thanks!
I've got a Pioneer 355 and it plays VCDs (and DVDs for that matter) very nicely.
Regards.Michael Tam
w: Morsels of Evidence -
i have a GO.Video Sonic Blue DVP950... really good for playing vcd's .. dvd's... dvd-r's... cd..mp3... i havent tried dvd+r's yet though.
APEX DVD players are the best and there dirt cheep they will play any thing back VCD SVCD DVD-R's
circuitcity.com has the Apex AD1200 still onsale for $49 with free shipping. I've had mine since last summer, and it plays everything I've put into it, DVD, DVD-R, SVCD, VCD, CD, CD-R, CD-RW, and MP3. I was able to enter the hack code to make it region-free. If you have a Circuit City store close to you, you can walk in, buy it and try it for 30 days, and if you really hate it return it for a full refund! It's a win-win situation!
It should be noted that (unless they have reveresed their decision) that new Apex machines no longer support VCD due to licensing issues.
Secondly, if you want good S/VCD support (i.e., a machine that supports most the commonly used feature set in the S/VCD PBC properly), you should probably steer away from an Apex.
Regards.Michael Tam
I have a older Apex 1100W 1meg version that plays everything very well i got it awhile ago for like 53$ and i also picked up a mintek 1600 at best buy for 49.99$ about 3 months ago and it is a pearl...very nice looking, black (couldnt stand that silver box of crap no longer on top of my all black setup), very quite, plays everything i throw at it and its also cheap! i would suggest it.
[ = Check out my band @ www.samadhirock.com = ] -
i have a Jocel MP3000 (or Apex AD600) and it supports everything i do from vcd/xvcd/svcd/xsvcd/cvd/miniDVD/DVD-R/MP3 all tested (bit rate must be <4000bps for miniDVD
i test some DVD players and Nintaus seems to be very good and Philips as some models that read also a lot of formats (xsvcd w/subs)
some cheaps DVD w/a great support for formats have a loosy quality image
so just get some cds w/differents formats and go to the shop and test, if...
2man
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 12:37 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 07:50
