Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Sorry, a new fresh 9v battery.
    Cut a paper clip in two.
    Red wire to +9 volt battery side.
    Black wire to -9 volt battery side.
  2. the fan still work thanks for the testing tip.
    but it's not powerfull enough 50*C for the cpu temp. what the temp range for good??? i was so pissed i broke the stock fan into 2pieces.
    thanks alll now i need a recommendation on the new good powerfull fann that's cheap.
  3. one more thing, the 3pins for cpu fan on the board doesnot work. it wont turns the FAN on i have to hook the fan to the power for the accesssories of the cases. everything else is working good.
    Mar 2002
    San Antonio, TX
    I'm using a Thermaltake Volcano 9. It can be set up several ways, a)using a thermal strip under the CPU to very the speed of the fan b)direct full speed or c) using a variable resistor to set the speed to what you want . I use option c to keep the temp under 50c and to keep the noise down. This unit can be very loud. Cost around $20.00 but I think it is worth it.
  5. i got everthing works out now
    bought the antec chassis fan from bestbuy and hook it to the stock heat sink. it works great temp is 35*C. i think fully load should be like 40*C eheh that's good?
    Mar 2002
    San Antonio, TX
    Glad to hear you got all the problems worked out.
  7. You started out with the wrong fan. It should hook to the MB connector. You are VERY LUCKY you did not overheat and fry the chip. Don't know about 15 seconds, but an AMD 1800 put a large blister on my finger from a very brief touch in 5 seconds or less.
    I have had good success with the ThermalTake fans and have yet to replace a defective one, these things really blow!
  8. i have the rite stock fan hooked to the MB at first but the fan wont turn on so i went to bestbuy and got the antec chassis fan 12.99 and tied it on top of the heat sink. it works great a lot cooler than the stock fan 37C idle. the stock fan idle at 50C
  9. I had an almost identical problem. The solution was simple: I set the FSB speed on the motherboard to 100MHz. It then started fine. After I 'd installed Windows, etc, I reset the bus speed to 133MHZ. Been ok ever since.
