Hi, I have an XVID file that I am trying to put onto a DVD to play in a standalone player. I extracted the audio with Virtual Dub into a .wav file. Then I used TMPGEnc to convert the video file to MPEG-2. I used BeSweet to convert the .wav file to AC3. Now when I multiplex the AC3 file and the MPEG-2 file together the audio is off sync. Also, my AC3 file will not play for me by itself and I do have the codec installed for AC3. I've tried converting the .wav to AC3 multiple times with the same results using the exact instructions from the online guide because I thought the AC3 file might be the problem. I was thinking I could fix the audio sync problem with TMPGEnc, but I thought there might be an easier solution. Ok, thx in advance!
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 11:08 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 06:48
