OK the first question I read in a post that they used Vdub to decompressed a video and then used TMPENG to encode. Is that something you have to do or is it only for certain situations. Also I made a slide show of family pictures using Movie Maker2. I had it set so that the music faded in at the beginning and faded out at the end, problem is that after I burned it it does not so either. Instead it will start as soon as I press play and after the slide show the song will just keep on going. I have tried to fix it but I get the same results. Is there anyone here that maybe able to help me. Oh and what I did to the music was I drag it back to make it shorter then I right clicked and clicked on fade out. It works good as long as you are in Movie maker 2 but when you burn it and play it throught Media Player then the song will keep going even after the slide show has stopped. Thank you in advance!
Results 1 to 1 of 1
Pan to Next Slide
By stefanj in forum ProgrammingReplies: 0Last Post: 3rd Dec 2011, 10:26 -
High definition slide shows on DVD.
By EagleW in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 16:17 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
Best programs for .jpeg slide shows?
By Captain Satellite in forum Newbie / General discussionsReplies: 17Last Post: 30th Oct 2007, 10:50 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
