What does it mean by DVD authoring? What is the difference between that and general use?
The recorder that I plan to buy says that it does not support DVD-ROM. Does this matter? What is it used for?
Results 1 to 11 of 11
Thx in Advance!!
DVD authoring is taking your video and graphic elements and incorporating them in to a file structure that a DVD player can recognise by creating menus, first play items, end actions etc...
A DVD-ROM is something that is playable in DVD-ROM drives in a computer, it is basically just a bigger CD-ROM. Your average Cd-ROm can hold 700MB of information, and your standard DVD-ROM can hold 4.37GB of information (a standard DVD 4.7GB DVD-R) -
Would it matter if my DVD writer does not support authoring or DVD-ROM creation? Why would some writers not support authoring, when (i believe anyway) that you can make them on CDrs?
Thx in Advance!! -
Not all DVDR are created equally.
General DVDRs are what most people use.
Authoring DVDRs are better grade media for use as a master when you send to a duplication house.
Most DVD writers should support DVDRom, while only a few support DVDRam. -
The drive in question reads all DVD- media, its the writing I am concerned about. I have found that it writes all DVD- media, but on the table I am refering to, the "write" values for DVD-r(for authoring) and DVD-ROM discs are left blank. This may mean it is untested, but as it is a table produced by the drive maker I think they know it wont work. It says that the drive can read both these values, but does not specify whether it can write them.
Thx in Advance!! -
Any DVD burner will be able to create and read a DVD-ROM disc as long as it is a computer based drive you are looking to buy. If it is a stand alone set top unit, then you will not be able to make or play DVD-Rom's.
why don't you tell us which drive it is, and give us an url.....?
http://www.dvd-recordable.org/modules.php?op=modload&name=Reviews&file=index&req=showcontent&id=45
I am refering to the official spec sheet that is available to download from here (pdf format)Thx in Advance!! -
I see the problem. look at the table again. Now, the category DVD-ROM has no write speed and a 12X read speed. this is because a DVD-ROM (Read Only Memory!!) can only be pressed, in a big pressing factory, not burned in a burner. While a DVD-ROM and a DVD-R can both hold an identical file structure recognisable by a computer, the media are totally different.
So a DVD-ROM reader will not read a DVD-R disk. I think I've got it
Thx in Advance!!
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Roms & Emulators on a USB External Hard Drive...will it work?
By Xenogear900 in forum ComputerReplies: 3Last Post: 28th Nov 2007, 17:31 -
@^DVD-Roms wont Read Dual Layer^@
By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 19:13
