Got loads of films which are in xvid format.
I've converted avi to mpeg before, but vitualdub wont accept the file type XVID (it loads it but when I save the wav it says no wav to save)
I used something called avi2wav which looked like it worked, but I'm not sure.
Then I used TMPGEnc Plus but it just keeps on bringing up errors.
What can I used to convert XVID to MPEG? I'm having so much trouble.
Do I need to have a certain codec? My media player plays the files ok. using something called divx total pack.
Get Xvid codec at xvid.org, then virtualdub will work, and you can just use TMPgenc plus to convert the file.
We came, we saw, we kicked his ass!
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 17:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 01:31
