Hi all,
I'm kind of new to this 'backup' stuff, but I have successfully burned over ten movies. I'm having a problem with Matrix. During playback of my burned copy, about every 15 minutes, the movie playback seems to jump back a second or two, repeat those few seconds, then jump ahead a few seconds to a point where I guess it should have been if there was no skip. Does that make sense? I think I have stated it correctly. Anyway, this is the ONLY movie this has happened to. I know Matrix has been a problem to some people. I kept menus and extras too.
I use DVD Decryptor, IFO Edit, DVD2ONE, and RecordNow DX.
Any help would be appreciated, before I make a second coaster.
This forum is very informative!!!![]()
What are you using Ifo edit to do?
Don't give in to DVD2ONE, that leads to the dark side. -
My first thought would be that you didn't select to rip/backup only one angle (the matrix has multiple angles for different scences).
it's the white rabbit scenes that's causing it
one will be the bit where Neo says 'Welcome to the real world!' after so long
read this other post here (http://forum.doom9.org/showthread.php?s=&threadid=49641) using IC and see of it's the same problem
I posted a way to fix it here
http://forum.doom9.org/showthread.php?s=&threadid=49955
are you using PowerDVD to play it, cos apparently that's the cause but you mention your burned copy, so is that in your standalone also? -
Marco33,
I am using IFO Edit per BarryHL's Guide on "How to copy a DVD9 to DVD5 with menu & extras using DVD2ONE." I have successfully made 10 DVD copies of various DVD's using Barry's guide, and have not had a problem, until The Matrix.
Vejita-sama,
In fact I did only rip/backup one angle of The Matrix.
MackemX,
Yes, but backup has the same glitches, at the same points, on any DVD player I tried: Philips DVD740VR, Toshiba SD-4800, Apex AD-1200, & Samsung DVD-612.
What exactly are the white rabbit scenes? If you are talking about 3:00 minutes into the film, where it shows the white rabbit on the back of the girls shoulder, that scene works fine. As far as between chptr's 10 & 11, they flow smoothly: no jumping parts.
I just tried DVD Shrink 1.03 and the jittering is worse when played off the Hard Drive, so I'm not even bothering with burning it.
I just checked out your link: is there a guide somewhere that explains "demux" & "remux" in detail? -
To all,
I found the problem to the jittering!
It was the ripping portion. What I found (after re-ripping with DVDDecrytor) was the skipping and jumping was right after I ripped. Just for kicks, I ripped with SmartRipper and no more skips anywhere in the movie! Yohoo!
Of course my new issue is making it all fit on 1 DVD5.
Can I just leave out the extras to keep the video quality of the movie? Will that corrupt the final product in any way?
I knew with a little playing around I'd figure something out.
VHS jitters with TBC turned on
By timmus in forum RestorationReplies: 10Last Post: 19th Aug 2015, 12:37 -
HandBrake Video Jitters During Panning Scenes
By ejai in forum DVD RippingReplies: 10Last Post: 14th Feb 2011, 14:50 -
Jitters with 23.976 AVI need opionions..
By funkymix in forum Video ConversionReplies: 8Last Post: 5th Apr 2009, 17:36 -
A NOOB overcomes the jitters (a workaround)
By dADDo in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2007, 03:24 -
Help; DVD plays in frames; Sound Jitters
By Brother Ali in forum Software PlayingReplies: 7Last Post: 1st Jul 2007, 04:50
