I used to be able to burn VCDs and SVCDs (using CD-RW media) with VCD Easy (I don't recall which version, but it was almost a year ago) using my Win98FE system. I no longer have this system and now use WinXP on an AMD2100e ECS K7S5A.
With the CD-RW on the XP system, I can reliably burn drag-drop files in Windows Explorer. The CD-RW firmware is up to date and the driver has been updated for XP.
With VCD Easy 1.1.5 (I have also tried earlier versions), when I try to blank a CD-RWs, I see the following log information:
[CDRDAO blank]
WARNING: During writing you should avoid to open the Windows Explorer and similar tools
WARNING: CDRDAO does not lock the recording device so that all access action from the Explorer will lead to a failure of the recording process.
Cdrdao version 1.1.7
ASPI: C:\Program Files\ahead\Nero\WnAspi32.dll
3,1,0: HP CD-Writer+ 7200 Rev: 3.01
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
cmd finished after 0.000s timeout 20s
ERROR: Cannot set write parameters mode page.
Blanking disk...
Blanking time: 95 seconds
Disc blanked
As you will note, an ERROR is showing (Cannot set write parameters mode page). However, the disk seems to have been blanked.
If I try to write some NTSC files (MPEG stills) with VCD Easy, I see the following log information and burning terminates:
[CDRDAO Write]
Starting write simulation at speed 2...
ERROR: Cannot setup disk-at-once writing for this drive.
ERROR: Simulation failed.
ERROR: Note that CDRDAO troubles are often related to the use of an inadequate driver...
ERROR: You may have a bad "Force Driver" in the "CD Writer/Reader" settings page.
The Force Driver is correctly, for the HP7200e, being set at "generic-mmc-raw".
I initially had trouble getting the CD-RW to be recognized. I first installed ASPI 4.6 using ForceASPI and the CD-RW wasn't found. I then used the Nero ASPI and I could then see the drive.
I have tried to use Nero to burn, but it has problems with the write parameters as well.
Any clues as to solutions for these problems?
Thank you
Gordon
