I'm thinking of buying me a dell computer but i'm wondering who makes their DVD +R/RW and can i apply the DVD bitsetting on it ???
Results 1 to 10 of 10
Open the computer case on look the sticker on it.. but I would bet on a Toshiba.
Thank's for the reply, but i can't open the computer case since i haven't bought it yet. My biggest concern is that i can't apply the DVD bitsetting to it to make it beleive it's a DVD-ROM. Until i know this i will wait to buy it.
I have a DELL 8250. It has a NEC DVD +R/RW burner....
Originally Posted by ChrissyBoy
I also have the Dell Dimension 8250. The DVD +R/RW is a NEC1100A DVD burner. -
i have a dell dimension xps t500 and ordered a DVD+R/RW burner and it is a philips
Justin
:agree: -
OEMs will buy from ANY vendor as long as the spec is the same as what they need. You can never tell so don't bother.Originally Posted by sven_pether
As Forrest Gump said"you never know what you're gonna get"until you get the PC out of the box.Dell catalogs never specify who makes their drives(Gateway also).
...i have a new (4Q02) dell 4550, and the cd r/w slash dvdr/w is a nec1100a...
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
Dell Makes an I7 System for $1K
By Soopafresh in forum ComputerReplies: 15Last Post: 28th Jan 2009, 17:26 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 09:17 -
DVD Burner for a Dell laptop
By PhoneMatt in forum ComputerReplies: 5Last Post: 26th Oct 2007, 13:15 -
DVD Burning on Dell Latitude D520
By chrang in forum Newbie / General discussionsReplies: 7Last Post: 20th Jul 2007, 13:00
