someone must know the answer to this as i've seen posts from other people with the same problem but with no replies!!
i'm trying to convert avi's with 48khz audio to vcd which is 44.1 khz audio with TMPEGenc. the metallic sound happens somewhere in the frequency change as i had the same problem when ripping dvd's but dvd2avi has a function that will change the frequency and this works when ripping from dvd's.
the problem is when converting avi's dvd2avi does not support audio conversion on avi's so it is not a feasable option. i've tried many different routes including using toolame and SMPX as the audio convertors, i've also used vdub to rip the audio to a 44.1khz wav and this still doesn't work.
i'm at my absolute wits end, there must be a way round this but after spending 6 days working on it , i'm begining to think there isn't
any input would be most apprieciated
the fault is also on the official tmpgenc forum but there is still no real answers
please help
I've found that problem too. You can virtually eliminate (through my experiences) that metallic sound by using the Shibatch sampling rate converter. Using a different mp2 encoder doesn't seem to make as much of a difference as this external sampling rate converter. I noticed a huge improvement. You can download the converter at http://freshmeat.net/projects/ssrc/ which is the 1.28 version. The only problem is that the overall encoding time is longer as Tmpgenc needs to decode the audio track to a wav file (which can be pretty big when dealing with an entire movie) and then ssrc (the converter) creates another wav file about the same size - the problem is hard drive space. Hope it helps though.
AVI converting sound issue
By wickerstick in forum Video ConversionReplies: 1Last Post: 23rd Jul 2009, 07:53 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 18:12 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
After converting FLV to AVI, there is no picture, just sound!
By lowfell in forum Video ConversionReplies: 3Last Post: 22nd Apr 2008, 16:48 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 07:02
