I know I cant make a VCD or any video for that matter look DVD quality, but is there a way to "clean up" a VCD? There has to be a way with some software.
When making a VCD 99.99% of the quality depends on the source file. If your source file is not that good quality than your VCD won't come out any better. Now I assume that you are making VCDs using avi files, and if you are, when using software to encode you have options to filter some things. Such as sharpening the picture, noise reduction etc. But I've tried them all and when I used them I just wasted more time, and my movie quality was not improved at all. So always try to get a good quality source file, because there no way cleaning it if its not good.
The noise reduction filter in TMPGenc works great!
Often when you shoot your own videos you dont use as much light as you should and so on..
This filter make the video smooth and nice to look on.
But it takes 20 hours or so to process per 1 hour video.
(It took so long with me 850mhz, maybe twice as fast now with my 1600mhz. i havent tried yet.)
If you shoot your own videos and have alot of noise (small dots all over it)
Then i would give this filter a go. It does a really good job and makes the video smooth. There is a preview so you dont have to encode anything to see the difference.
Cleaning the lens?
By Digiface in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Sep 2008, 11:27 -
Cleaning up Picture?
By LCE in forum Video ConversionReplies: 2Last Post: 15th Nov 2007, 11:47 -
Cleaning the screen
By BroomQueen in forum DVB / IPTVReplies: 1Last Post: 16th Oct 2007, 07:02 -
I need some help cleaning up Audio.
By efb91 in forum AudioReplies: 1Last Post: 22nd Sep 2007, 14:28 -
Guitar Cleaning
By Squid_uk in forum Off topicReplies: 9Last Post: 24th Jun 2007, 02:17
