Hello,
Im trying to back up a dvd to vcd, but it seems to have pcm audio, which doesnt wanna work with forty-two or ffmpegx-the easiest ways to go directly to vcd for me. Can someone please tell me the easiest way to get this dvd backed up into mpg-vcd, that will work with the pcm audio of the dvd? I really really need some help guys! Thank you for your time.
-Tolly
What DVD is it? Does ffmpegX have problems w/PCM audio? Could have sworn I've backed up DVDs with PCM audio....
well its weird...
forty-two tells me it contains sumthin other than ac3 or it is totally pcm and it wont let me to continue but says i can make divx. but i seem to be able to extract ac3 files from it in osex, yade, etc., whats up with that?
then in ffmpegx i have problems too. it doesnt convert, it just stays at this step:
Encoding started on Sun Apr 20 23:20:46 PDT 2003
## Component Manager: attempting to find symbols in a component alias of type (imdc/MPG4/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP42/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP4S/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (sdec/MS42/FhG )
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP43/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
it is the "50 Cent - The New Breed DVD" that i am backing up for my brother. Anyone know whats goin on?
maybe i should rerip and start over, any ideas? HELP ME!
-Tolly
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 23:17 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
