Evening all, I am trying to load an SVCD into TMPGEnc but am getting a message that says "can not open or unsupported". I am trying to lower the quality a little so I can fit 2 files on a CD. I have played with the Direct Show File Reader settings all the way from -3 up to 5 and no go. Any ideas or another way to do this??? Thanks!
Current versions of Tmpeg require you have PowerDVD installed in order to open mpg2 files.
TMPGEnc only encodes to MPEG2 (SVCD/DVD) and won't decode MPEG2 video files, so they cannot be opened directly in TMPGEnc. Use DVD2AVI to create a.d2v file and then open this in TMPGEnc. DVD2AVI wil decode and then 'frameserve' the MPEG2 file into TMPGEnc.
DVD2AVI is available in the 'Tools' section of this site. -
Thanks for the replies, was just about to try both suggestions when I found the mpeg-2 plugin, it works fine now, thanks for help!
Yeah it reads them, but it is not a part of the package. It must be provided by a third party program. PowerDVD, DVD2AVI, an MPEG2 Codec which decodes them for TMPGEnc. Just like MPEG1, Microsoft's decoder takes care of that, not TMPGEnc.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
