I have created a homemovie with ATI all in wonder card in dvd format. No problems with audio. I then frame served the mpg file from virtdub to TMPGEnc to get the file to on dvd size. No problems with audio. I then used ulead moviefactory to create chapters and put some extra pictures on the dvd and burn it. Plays fine on PC but no audio on my home DVD player. Any ideas?
using AVIcodec the audio format is shown below. Is this format not supported by dvd players? How can I change it?
Audio : 0.0 b, 192 Kbps, 48000 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported -
MPEG Audio encoding is not supported by all DVD Players.
Works on mine and 3 of my mates, but not on my sisters.
Real shame as PCM takes heaps of space and not all software supports AC3, but that's life I suppose.
Try encoding something as PCM just to prove that is in fact the problem. Most authoring programs with have an option to convert to this format (eg. DVDWS, MyDVD, etc) -
This is the strange thing in MovieFactory the settings are set like this
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC)
Video data rate: Variable (Max. 8000 kbps)
LPCM Audio, 48 KHz, Stereo
So why would AVIcodec say that it is mpeg? I thought that MF only supported PCM? -
Can't answer that one. The file size alone should be a good indicator.
(You could always de-multiplex and check out the size of the audio stream.)
I only ever had the trial of MF 2, which does allow mpeg audio.
Most of the Ulead packages allow you to get the Properties of the files you are loading or have loaded ... ?The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be.
No dialogue, but other audio works fine
By MCPorche in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2012, 21:07 -
M2TS File No Audio in Premiere (works fine in VLC)
By koberulz in forum AudioReplies: 22Last Post: 6th Oct 2011, 02:46 -
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 15:07 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 12:09
