I'd greatly appreciate any advice on the following problem. I'm new to capturing from VHS. Installed an ATI All-in-Wonder Radeon 8500DV capture card. Capturing seems to go fine, but the resulting video playback is just a frozen, jiggly picture of the first frame, with normal audio. I've tried four different software packages and all net the same result (VS6, MyDVD, ATI's TV applet and even Microsoft MovieMaker). I'm going for the MPEG2 format so that I can burn to DVD.
I'm using a Dell 1.7 Ghz machine with 512 MB RAM, HD controller set for DMA, WinXP Pro. Tried two different VCR's; current one is a Sony.
Thanks in advance for any assistance.
CC Hall
Read this:
https://www.videohelp.com/forum/viewtopic.php?t=164687
It may help.Want my help? Ask here! (not via PM!)
this actually sounds like a macrovision protection problem...I cannot find the link in the TOOLS section any longer for disabling macrovision with ATI, but you might try here:
http://www.doom9.org/
and searching for "disable macrovision" -
I don't think it's a macrovision problem, what's your source?
Try reducing the format of the capture to a smaller size, for instance if you're using 720 x 576 try, just to eliminate this risk, say 480 x 320 or something.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Capturing VHS with ATI TV Wonder HD600 PCI card
By CamaroDMD in forum Capturing and VCRReplies: 12Last Post: 17th Jun 2010, 07:58 -
ATI or NVIDIA capture card for VHS?
By Smile_M in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 06:43 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 14:34
