I'm fairly new to this. I've had some good luck but can't seem to be able to figure out the setting for ifo edit after I use dvd decrypter. Is there somewhere that I can find a simple illustrated guide? I've tried to do a lot of searching through the the forum for a solution but a couldn't find the answer! I've also run into problems using smartripper and Windows XP. I know I have an ASPI driver with Windows XP, but that seems to be causing a problem. I tried opening Power DVD to get it to work, which made it appear to solve the problem, but it actually didn't. Can anyone help me with either of these questions (or both). I have had several dvds turn out great using dvd decryter and instant copy, I just still need a lot of help! Thanks ahead of time.
lo m8 .. right where to start. the seetings for ifo edit are on this site somewhere as i had them .. but i found that some films done with ifo edit would cut half or last quarter of a film out. so i cahnged to dvd2one and instant copy and i would suggest u do the same.. as for win xp and the aspi drivers goto the tools page on here and get the force aspi drivers .. that will sort out youre problem with smartripper . i used to use smartripper but now use dvd encrypt which does a splendid job.. hope some of this helps .. if u carnt find settings for ifo pm me and ill see if i got the old guide for u .
sheesh
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 16:45 -
DVD Decrypter - Time based settings?
By badboytim999 in forum DVD RippingReplies: 6Last Post: 11th Nov 2010, 15:17 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
DVD Decrypter IFO I
By drstew in forum DVD RippingReplies: 6Last Post: 2nd Dec 2007, 23:42
