i hav a clip here which has ac3 audio in it, but when i extract the audio, there isn't any sound...i use vdub to extract the audio..then when i put it into winamp it tells me the codec is missing..but all the regular avi wav files still play, ive also downloaded the ac3 codec but that doens't help much, has anyone ever had this proble, before...holla back
Results 1 to 10 of 10
try extracting the audio with goldwave. Open the video file resave the audio as .wav then put the sound back on (vdub or tmpgenc)
so im now guessing that goldwave has the codec to accompany this file, to render sound..holla
i have only just figured this out but if the video has ac3 sound the easiest and (in my opinion) best way without any messing about is to use goldwave - a demo is in the tools section on this site
No, it doesn't have the codec. You must d/l the codec and install it first.Originally Posted by SIRCOOKS
"Art is making something out of nothing and selling it." - Frank Zappa -
yah, i just figured that out, i had to install it after goldwave, so when im finished what im doing ill just restart my comp and everythting should be aiight right.....
so does gold wave works on extracting the ac3 from the video clips then ?
i am curious coz i have the same problem
hey i downloaded godlwave and tried on my ac3 xvid video and it works on extreacting the wav files
i dont understand the program man, can any one point me to a guide of some sort or tell me how to get the wav file from my movie using gold wave..holla back
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
