Hi. I ripped my DVD to elementery streams using 0SeX, then built my DVD in Sizzle, then dragged the generated VIDEO_TS folder into Toast to burn a DVD and after I click burn insert the blank DVD-R and click Write Disc I get this error:
The drive reported an error:
Sense Key = MEDIUM ERROR
Sense Code = 0x73, 0x03
I have used this process once before and t went fine, so I don't know what is going on. Anyone know what this error means? I thought maybe it was a bad DVD, but I tried another one and it was still messed up.
Thanks for any help you can give.
Medium error occurs when you have bad media typically. Try a different brand and see if that fixes your problem.
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
Sense Key = Medium Error sense Code = 0x73, 0x03 in Toast
By arythmic in forum MacReplies: 37Last Post: 27th Nov 2012, 18:46 -
Toast 9: The drive reported an error
By soundchaser in forum MacReplies: 16Last Post: 1st Jul 2009, 14:55 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 12:46 -
LaCie / Toast / DVD+R DL Error
By webstar in forum MacReplies: 6Last Post: 4th Aug 2007, 11:53
