I can't seem to get interlaced PAL output from ffmpegX 0.0.6i.
Input: Full quality DV encoded PAL QT file exported from iMovie 2 with its High Quality flag set and saved in QT Player.
ffmpegX settings: SVCD (PAL) Quick Preset, mpeg2enc Deinterlace unchecked. I have tried all ffmpegX's Interlace options (Field, Frame, Not interlaced) but the output is always progressive (i.e. there are no comb lines on computer monitor). I can get good interlaced output via MediaPipe's ppmtoy4m -L -I b and mpeg2enc -I 1 settings.
Is there some ffmpegX option I'm missing?
What is the difference between ffmpegX's Field and Frame options? With the Field option there are similar colored artifacts I get via MediaPipe's mpeg2enc -I 2 although the output is progressive with ffmpegX.
Output file is a mess - judder & interlaced....
By The.King in forum Video ConversionReplies: 6Last Post: 29th Jan 2011, 21:44 -
progressive input gives interlaced output...
By bennn in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2010, 12:32 -
VirutaDUB Interlaced Output and Audio Errors.
By vodmare in forum Video ConversionReplies: 25Last Post: 16th Aug 2010, 06:42 -
FFMpegX Output files
By Dearg800 in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2008, 15:50 -
How (exactly) does my camcorder generate interlaced output?
By wayback in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Jun 2007, 18:21
